Thread: Tire brushes
Old 04-29-2011, 03:00 PM   #1 (permalink)
XJguy
XJguy's Avatar
Tire brushes
I dont recall where I read it, probably in Race Car Aerodynamics Designing for Speed, but some drag reduction can be had by preventing the air pumped by the tires from making its way around. This is why you see louvers mounted on top of some race car wheels. Another method to do this is to having body work which would be in contact with the actual tire...obviously that would not be possible, but a brush would...like a broom. By affixing a brush to the body or suspension to remain in contact to the tire tread you can prevent the air form making its way around....it would then have to be ventilated/extracted out of the wheel well. The contact would have to be minimum in order to not add drag to the wheel negating its benefit.
