Thread: Two overdrives?
Old 04-29-2011, 04:05 PM   #36 (permalink)
cleanspeed1
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Honda Accord EX
HvyDrnkr - '93 Cadillac Seville
What's the lowest numerical ring and pinion that you can get that will fit both the axles?
Or if you don't uses the 4x4 feature, disconnecting the driveshaft to the front axle and using a different ring and pinion in the back only?
