Old 04-30-2011, 02:32 AM   #5 (permalink)
abently
turquoise - '97 Toyota Starlet
90 day: 41.46 mpg (US)
Originally Posted by dcb View Post
the other option, and I should probably implement this on the prebuilt, is to display the counter for the number of pulses for the tank trip and then after a couple careful refills it should possible to figure out what the injdelay should be.
This is assuming that the owner knows the exact flow rate of their injectors, otherwise there will always be two variables, i.e. the injector delay and flow rate, correct?
