Thread: Tire wear help!
Old 04-30-2011, 05:47 AM   #8 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by barkl0r View Post
Also; I don't notice anything rubbing. I will have a good look when I go to check tire pressures today.
Put some coloured blackboard chalk on the tyre surface and push or slowly drive it forward.
If it rubs, you'll see it on the chalk, and the chalk will go on whatever the tyre rubbed onto.
Then drive a bit around the block and see where most of the chalk remains - it should be gone or be reduced evenly.
The Following User Says Thank You to euromodder For This Useful Post:
barkl0r (04-30-2011)
