Old 04-30-2011, 08:50 AM   #7 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Originally Posted by bobski View Post
The only way you can get around the delay time issue is to use injectors that open instantaneously. ..
Sorry to be pedantic, but it is the difference between opening and closing time that we are accounting for. If you had injectors that took the same amount of time to "open" after the current is applied, as to close when the current stops then you would not need to account for the difference. Such injectors are not currently practical however (and we have workarounds).
But I do also like the OP method, gives me some ideas for measuring other things. I would be curious to see how much accuracy improves after changing to 850ish.
