Old 04-30-2011, 01:57 PM   #245 (permalink)
jamesqf
Originally Posted by Thymeclock View Post
Boom! Once again James thinks he can provoke and win an argument by an aggressive response...
There you go again, accusing others of practicing your own behavior :-)
...never quoting anyone or responding to the point made...
Perhaps there is a problem with your browser? When I look back at my previous posts, I see plenty of quotes. Or perhaps you're annoyed because I practice the courtesy (long commonplace on boards where intelligent discussion takes place) of not repeatedly re-quoting entire posts, but just enough to serve as a pointer back to the original? May I suggest that this is more a problem with your lack of attention span than any fault of mine? Certainly I find it makes reading threads much easier. And may I point out that unless and until you are appointed a moderator, you do not set the rules here.
(I'll also note that neither the style nor the content of my comments seem to have bothered anyone else, so again, if you want to get to the root of the problem, a mirror might be quite helpful.)
Apparently you have been watching too much of David Letterman's "top 10 list."
Merely to demonstrate how wildly off-base you are, as a matter of fact, I've never owned a television set, and watch it only on the rare occasions when I'm constrained by courtesy, as when visiting friends. Wouldn't recognize Letterman if I met him in the street.
