Vacuum guage on a Ducati V-twin...
As far as I am aware, my Ducati ST2 has the two throttle bodies side-by-side botled together and sat between the 2 cylinders.
However, each throttle body then feeds into an individual inlet manifold per cylinder.
Could I run a vacuum guage off of just on inlet?
Would it be far to 'bouncy' for an accurate reading?
Could I take a feed from each inlet manifold and join them with a 'Y' style connector, or would this ruin the vacuum in the cylinders?
I'm confused....
