Thread: Two overdrives?
Old 05-01-2011, 09:04 PM   #43 (permalink)
Big Dave
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
The GV overdrive is a single planetary spur gear setup. Expect a 3% loss in driveline efficiency, but this will be more than offset by the lower engine RPM resulting in lower engine frictional HP.
What concerns me about t_vago's setup is reduced cooling in the automatic transmission due to the big overdrive ratio.
I had a GV on a 1983 GMC K2500 with a TH400 tranny and the wimpy old 6.2 engine. I destroyed not one but two TH400s in front of the GV. Once I raked up the parts from the Interstate, I took them to a transmission guy and he said excessive heat buildup.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
