Thread: Two overdrives?
Old 05-01-2011, 08:25 PM   #44 (permalink)
cleanspeed1
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Honda Accord EX
HvyDrnkr - '93 Cadillac Seville
Originally Posted by Big Dave View Post
The GV overdrive is a single planetary spur gear setup. Expect a 3% loss in driveline efficiency, but this will be more than offset by the lower engine RPM resulting in lower engine frictional HP.
What concerns me about t_vago's setup is reduced cooling in the automatic transmission due to the big overdrive ratio.
I had a GV on a 1983 GMC K2500 with a TH400 tranny and the wimpy old 6.2 engine. I destroyed not one but two TH400s in front of the GV. Once I raked up the parts from the Interstate, I took them to a transmission guy and he said excessive heat buildup.
I would think synthetics and a huge by large trans cooler with a fan would help with that, but you are talking more about pump speed, correct?
