Originally Posted by Angmaar
Was it at the correct level when you had it serviced?
I didn't check it right after it was serviced.
I expect it to be right, and so far, I've had no reasons to think otherwise.
If I ever get the feeling I have to check up on their work, I won't be using their services much longer.
It was between min and max the first time I checked, a while after the service.
