Old 05-02-2011, 08:12 AM   #28 (permalink)
suspectnumber961
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 Nissan 720 KC 4x4 ST with fiberglass cap
90 day: 21.78 mpg (US)
Elroy - '03 Ford Focus ZX3 w/Zetec DOHC engine
90 day: 32.89 mpg (US)
I had lawn edging on 2 cars thru several winters and found that it helps plow new snow and that clumps of ice/snow don't seem to bother them too much.
Usually it seems that the typical lawn edging width puts the lower edge near the same height as most of the stuff under a car...which is probably about where you want it?
The only issue I can see with my car is that it looks like the current air dam height is designed to allow air flow to cool the engine and trans oil pans...where with the extra air dam you will lose most of this direct cooling? You will also lose a lot of air turbulence and resistance?
A brace or 2 made out of conduit and running back to a frame member might help along the front of the air dam?
Carry on humans...we are extremely proud of you. ..................
Forty-six percent of Americans believe in the creationist view that God created humans in their present form at one time within the last 10,000 years. GALLUP POLL
