Old 05-03-2011, 07:42 AM   #19 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Christ View Post
What about the boundary layer, frank? Are you thinking that because it's not a solid, the boundary layer "weeps through", and doesn't keep flow separated from the actual surface?
Air will weep through, even when it's perpendicular to the airstream, even at very high air speeds.
Examples ?
The rear F-4 splitterplates.
They are nearly perpendicular to the airstream.
F-15 movable intake ramp.
Here the holed intake ramp faces the airstream at high speeds.
