Also - WOT is normally defined as the throttle setting wherein the throttling device poses the least possible (unmodified) restriction to intake flow. Normally, when the skinny pedal is on the deck.
Zero vacuum can be achieved under any throttle setting, and thus, is a function of load, rather than throttle.
