Wow, this sounds familiar. Fix one thing, two more break. Repeat until the entire car has had a ground up restoration. Sounds like you've come a long way since beginning.
So, today was Tuesday. What did you get?
Since you are also part of the 'to many projects, not enough time' group. A few questions.
1. Do you work on the same project until finished, or jump from one to the next?
2. Having a lot of projects usually means having to many cars, bikes, engines, etc. Do you find yourself hoarding parts? Things you may never use again, but it's to good to recycle?
3. Are your projects and garage organized or scattered?
4. Do you ever feel overwhelmed by the amount of things needing fixed? Or are the projects something you look forward to working on?
5. Once you complete a project do you look to get another shortly after completion? Or drive and use the completed project for a while before moving on to the next?
VT247
