Old 05-04-2011, 07:36 AM   #26 (permalink)
cleanspeed1
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Honda Accord EX
HvyDrnkr - '93 Cadillac Seville
Originally Posted by rmay635703 View Post
Actually they did make vehicles sort of like this in the 80's it was called a 1982 C code 6.2ltr diesel. The trouble was, GM liked to fix things after making them, they also liked to couple it to crappy transmissions and they liked to put them into the wrong type of vehicles.
If you couple a 6.2 with a 5sp stick 2wd with good gears you can easily get in the high 20's to low 30's in a full size vehicle like a suburban. higher still if you can figure out how to fit it into something smaller like an S10 (you need to borrow the suspension from something beefier though)
Sadly GM didn't couple the 6.2 with good transmissions from the factory with a handfull of 1993 5sp pickup exceptions.
The 6.2 is capable of up to about 40mpg if in something moderately aerodynamic from what I here of the few who have done 5.7 diesel car to 6.2 conversions.
I had one of those beasts in a ex USPS truck. Good motor, but a bad combo for what I had ( wished I had a Cummins B3.9 ). Thing is though, with GM having access to smaller, more power dense engines and the engineering prowess of Detroit Diesel, why they wouldn't offer something better to our market.
