Originally Posted by MetroMPG
- 2) let the clutch out part way, smoothly & relatively quickly, only as far as needed to spin up the motor
- 3) immediately depress the clutch as soon as the engine spins up
The key is to let the clutch pedal out for a very short time and then press it back in.
You have to bump start with the key on so the engine starts up!
