Old 05-04-2011, 01:26 PM   #223 (permalink)
Freyguy
EV Builder
Freyguy's Avatar
Originally Posted by adamj12b View Post
The LEM Hass 300-s goes all the way up to 900A. 300A is just the nominal current.
-Adam
Yes, from the datasheet you can see the LEM Hass 300 up through 600 have a measurement range to 900A. Each model differs only in their sensitivity.
The 300= 2.08mV/A, 400=1.56mV/A, etc. The Tamura is 3.75mV/A which is why when you use the 300, you need to apply 1.8x gain in the code.
The LEM Hass 200-S is actually the closest fit to the Tamura. It's sensitivity is 3.125mV/A and would require a gain of 1.2 (multiplier value in code =19 vs 29 used for LEM 300). It's range is a bit smaller at 600A, but still higher than the 500A limit of the Tamura.
-Chris
The Following User Says Thank You to Freyguy For This Useful Post:
1-ev.com (05-04-2011)
