Those PVC sheets do look good but at >$50 a piece it would be too expensive to get multiple to do a complete test. However if I can find a %open hole area that works the PVC would be the best solution for an actual grill block because the stainless mesh gets expensive in larger sizes and the pliable meshes would need reinforcement to be used for a block.
