Thread: Turbo choices
Old 05-04-2011, 10:31 PM   #8 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Yep, going to intercool.
The smoke issue I was referring to is when making big boost on a n/a pump. You turn the fuel screw up, and that increases fueling across the board, so you get smoke off boost.
I believe my head gasket has stopped leaking since removing the rotor vanes from the vacuum pump. There was never a compression leak, so its not in bad shape that way.
