Mrbigh,
I'm not using the same setup as you, but I'll try to help. On your progammer, you may have to switch the order of the pins on the end. I don't know if this problem was changed on the 1000amp boards, but on the 50amp boards the ISP pins are mirrored. Meaning that pins 1 and 2 need to be switch, 3 and 4, and 5 and 6.
