Old 05-05-2011, 08:37 AM   #17 (permalink)
ChazInMT
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
Hi Phil,
I did a quick drawing of "The Template" over a web image of a 2011 Prius.
Some things to note:
The Prius back glass drops quicker than the plan taper.
In order to make up for it, I shrank the template a bit and lowered it to put it in a sort of compromise position that you see in the image.
I did this because it would seem to me that once the air starts moving along a given taper, it would be unwise to push it back up too much, I'd think a sort of go with it idea would keep the air moving as smoothly as possible.
The black line was used as a measuring device, it appears to me that a trailer would end at 82" or so if this line were followed.
Anyway, hope this helps.
Charlie
The Following 2 Users Say Thank You to ChazInMT For This Useful Post:
aerohead (05-13-2011), donee (05-07-2011)
