Old 05-05-2011, 12:21 PM   #4714 (permalink)
adamj12b
EVVette - '71 Chevy Corvette Coupe
Originally Posted by MPaulHolmes View Post
When Fran did the rewrite of the original software, he used a Linux build environment. I don't think I've ever successfully tried to compile the code in AVR Studio. Part of the issue was that AVR Studio had a problem with putting the hex file in a different part of memory than normal, because there was a bootloader. So, each time I make a code change, I log out of windows, log in to ubuntu linux, make changes, compile them, send hex files to my email, and log back out and try them.
I have had the same problem. I have never been able to successfully compile the firmware using avrstudio.
Its kinda a bummer because the tools in avrstudio are really nice once you figure them out. Like the simulator.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
