You are correct about the a-b-a tests I was wrong. I was not trying to slam you. However you seem intent on dismissing my test by saying some random stuff you picked up at a hardware store had some positive effect on your vehicle so there is no point in doing anything else.
I want to know what the effects of different mesh sizes have on the air flow through the mesh and if that can translate to effective grill blocking. Maybe I will get meaningful results maybe not. But that is certainly no reason to just not do it. I am the kind of person who enjoys doing the research and quantifying the results as fully as I can. I intend on doing the test I have laid it out regardless if others think
It's a meaningless discussion when in the real world there are several products that will serve the purpose.
I would appreciate constructive criticism on such things as how to make the test better.
