I'll put ~35 miles on the new tires today. First impression driving 3 miles home yesterday was how soft and quiet the ride was compared to the rock-stiff 44 psi inflated (max sidewall) stock tires. I just checked cold inflation pressure on the new tires. They were at 36-42 psi - with 51 psi max sidewall rating.
There will be a substantial weight penalty. The stock wheel/tire combo weighs 35 lbs per my bathroom scale. The new tires alone weigh 26 lbs, and I obviously don't have 9 lb wheels.
Mark,
Why do you expect I'll have to buy brake parts more often? Why are you assuming I'm doing harm to my car? I'll bet I can easily get 100,000 miles out of a set of brake pads since I so rarely use my brakes to stop.
I've made no claims denying harm or side effects. I'm simply making no assumptions, good or bad, until I do some testing and build some experience driving with the new tires/wheels. You, OTOH, are assuming the worst.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
