Originally Posted by Odin
i still think you're gonna run hell-a lean at 15psi which was a comment on topic because i think you should take that into consideration when picking a turbo- the comment about the 300zx turbo was a good idea , just my two cents best of luck with the build
also i think one thing everyone will agree with is get a egt gauge before you start, find out what your normal operating numbers are so you have something to reference once you do go turbo
Diesels are designed to run very lean mixtures ( 33 to 1 or better ) and boost is fuel dependent. As long as the fire isn't there, it won't run away boost pressure wise. The more available boost pressure, the better; keeps the egt's down.
