Thread: Turbo choices
Old 05-05-2011, 10:07 PM   #29 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
You mean tuning the LDA pump to make the power by itself, then just staying out of the pedal when I don't need to use it, right?
Seems like the easiest option, for sure. Really, I'd rather not use propane, because using it effectively mans retarding the injection timing, which I can't really do dynamically. Ok, that's a lie, but it involves a high pressure fuel pump and some electronics.... PITA.
