I weighed my stocker wheel/tire combo, & came up with 35 lbs on my bathroom scale. I replaced the tires just in time, as the fronts were down to less than 2/32" tread depth in the center. I was wrong about tread wear being even after hypermiling 20,000 miles. They were definitely worn more in the center on the two front tires.
Today's drive impressions:
New tire ride @ 51 psi on 50 series tires is about as rough as 44 psi on 60 series tires
Stock (185/60-15) tires showed 60 mph on speedometer and UG when GPS speed was 57 mph.
New (205/50-17) tires initially showed 60 mph on speedometer & GPS when UG was showing 56.5 mph.
After 5.6% distance calibration of UG, new tires now show 60 mph on speedometer, GPS, and UG simultaneously.
Car's odometer readings are now underreporting mileage by 5.6%.
I pulled >60 mpg driving home after distance calibration.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
