Finished again with fixing it, still needs minor tweaking. Got the timing belt, serpentine belt and alternator belt back on. Rigged a quick fix in for the shift stabalizer. Need to tweak it a little more and it'll be good to go. Filled it up and wanted to do a test run. But, it started raining and the wipers need replaced. Get some tomorrow. Going to put in a kill switch for the wipers so they'll stay up and down.
VT247
Here is the fix on the shifter.
While working on the Tempo
Cleaned up after
