Old 05-06-2011, 09:36 PM   #12 (permalink)
stovie
the green machine :P - '97 Jeep Grand Cherokee ZJ
90 day: 20.92 mpg (US)
Thee s10 - '00 Chevy S10
90 day: 24.27 mpg (US)
Freedom - '05 Kawasaki Ninja 250EX
90 day: 75.55 mpg (US)
i plan on taking my I6 and having 3 cylinders run off of compressed air so then you cut the fuel consumption down right there, then have a kill switch on the injectors that run off of the throttle body so that the injectors shut off completely at idle so you only use compressed air at idle and fuel when accelerating or cruising. (but only at operating temp) there's a 400 psi compressor for $1500 that i want for framing cause i'm in construction, i could use that for the compressed air to run my 3 cylinders. Then basicly make the throttle body into a 2 inch ball valve that closes all the way, killing air flow to the fueled cylinders at idle.
