Old 05-06-2008, 07:56 AM   #4 (permalink)
Daox
Adjust the value down. The advice I've gotten from others is make sure your car is warmed up with no accessories no and then see what the GPH (gallons per hour) are at idle. Set your cutoff just below that value and you should be good.
