Old 05-07-2011, 01:50 PM   #10 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by alvaro84 View Post
for now I surely can't go above 38 PSI with the front without compromising handling (I don't know how much it's different because it's now one size larger (120/70) than normal). That's not even 10 PSI above factory recommended.
If you mount a 120 instead of 110 on the same wheel, it'll be pinched a bit more, so the profile becomes more curved/pointed at the contact patch.
If you then also increase pressure, making the contact area even more pointed on a semi-circular tyre, handling will be negatively affected - it'll become very twitchy .
