Old 05-08-2011, 10:28 AM   #1 (permalink)
focus1.6uk
Low lift & drag aero ideas for hatchback track car
Hi,
new member here looking for your input on low lift and low drag aero ideas for my little track car (awaiting prep when i finish uni for summer)
Being unable to make the car longer rules out boat tails/ large kamm back extensions/ nose extensions like basjoos' civic. I doubt front wheel skirts or flat wheel trims would be possible either as the front brakes in particular generate a lot of heat on track.
Im thinking along the lines of:
small roofline extension/ small kammback similar to
http://ecomodder.com/forum/showthrea...ics-312-9.html
and Piwoslaw's 307
http://ecomodder.com/forum/showthrea...read-9040.html
flat undertray and side skirts- perhaps with VGs on the undertray
front splitter
possibly perspex rear wheel skirts
aerial/ rear washer jet and sunroof will be removed
extension on the rear of the bonnet to deflect air around the wipers as per http://autospeed.com/cms/A_2445/article.html
passengers side mirror delete or replace both mirrors with smaller ones
possibly sealing off the high pressure cowl intake in front of the windscreen or using it as place to have the air intake for the engine.
Venting under-bonnet (under hood) air out of either bonnet vents, a vent in the undertray or out the wheel arches, which may also help brake cooling.
Thanks for reading, I would appreciate any suggestions, feel free to flame any of my ideas
Name:	DSCF0002 ended 14 apr 11.jpg
ID:	8314   Click image for larger version
ID:	8315   Click image for larger version
ID:	8316   Click image for larger version
