Thread: adding guages
Old 05-08-2011, 12:23 PM   #1 (permalink)
deathtrain
Black Knight - '94 Toyota Corolla
90 day: 58.53 mpg (US)
adding guages
Ok had my car awhile now and have noticed a few things that I dont like. 1) my engine temp gauge has a "L" and then at the top small red line and then "H". Nothing to really indicate what the actual engine temp is. I have watched it to see where the needle is the most consistent at but it its not steady. So I want to add a real gauge with actual numbers. something like this
Blue Digital LED Water Temperature Gauge
2) I have no tach. I want to be able to watch the tach for the best shifts. Maybe get one with a programmable shift light to set it for the RPM I want for say XX MPH. So when i go over that set RPM the light will come on reminding the nut behind the wheel to tighten up. It will be a "Nut Check" light.
Red Digital LED Tachometer Gauge
I already have the MPGuino (yet to be installed) what else would be good to watch? I want to make sure i got everything at once so I can install it together. its a 94 corolla so no one makes a gauge pod for the piller. SO I will have to get my fiber glass out and mold it myself.
