Originally Posted by deathtrain
Ok had my car awhile now and have noticed a few things that I dont like. 1) my engine temp gauge has a "L" and then at the top small red line and then "H". Nothing to really indicate what the actual engine temp is.
Few cars I've driven indicated the actual temperature in °.
The middle position indicates the normal temperature - which is where the needle should be after warm up.
I have watched it to see where the needle is the most consistent at but it its not steady.
Strange, once warmed up, the needle usually never moves much at all.
Is your thermostat OK ?
