Originally Posted by Arragonis
If you have 250 lb/ft the A68 is a fine road South to North until it reaches Midlothian.
Midlothian is a little like Sainsbury's - time seems to slow down so much you almost feel like you are not moving at all.
Especially in the cafe.
Plus of course have you driven a Fabia VRS ? They don't like corners much
TBH those roads can be fast in a 1.3 Felicia if you can keep up the momentum!
I lived in Mid, and worked for the Council- its a touch "Deliverance"
Good roads though- esp the one from gorebridge to Penicuik- I used to be demon down that road in a Transit Connect
As for the Fabia- Get it on coilovers then- you're "conserving momentum" so you dont have to brake and waste fuel
