Old 05-08-2011, 11:02 PM   #1 (permalink)
justjohn
Black Beauty - '13 Hyundai Elantra
Ultragague questions - open loop, lean burn
Hi, so I got an ultragague and I'm loving the real time feedback. However, I'm a little confused about what's going on with a couple things.
Fist is open loop. I only stay in open loop for ~10 seconds when starting the car. However it shows open loop after bump starts as well. Should I assume that's correct? Is it unavoidable then? (And would that negate most of the benefit of engine off coasting?)
Also, it seemed to pop on occasionally while cruising down the highway at 55 this morning, and always seems to go on when my throttle hits 35% or higher. I thought it wasn't supposed to trigger until ~80%?
Which leads to the next question: Throttle only seems to go from 9.41% to 86%. Is that normal?
Last is lean burn. I read you can tell lean burn by when the rear 02 drops to 0V. I drove in what I think should have been lean burn conditions for a fair bit today and saw it drop to .035 several times and .015 once, but never 0. Am I not getting there, or is "near 0" what was meant?
Thanks!
