Thread: cng heater
Old 05-08-2011, 11:28 PM   #5 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
1. air is pretty inefficient At transferring heat
Try, instead, putting some heat wire elements in the seats. They can use less energy to keep you warm.
2. If you would rather use heat from cng, limit the area you're heating to only the spaces that you need to heat.
