Old 05-09-2011, 08:39 AM   #30 (permalink)
suspectnumber961
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 Nissan 720 KC 4x4 ST with fiberglass cap
90 day: 21.78 mpg (US)
Elroy - '03 Ford Focus ZX3 w/Zetec DOHC engine
90 day: 32.89 mpg (US)
Installed an air dam on the Focus using the Home Depot edging (now has a different name?). This stuff is not the best material to use...I should have tried to find some heavier pro rubber edging with more substance.
Did it a little different in that I cut off the extra 2 flanges and just used the straight edge...fasted every 6" using pan head SM screws and flat washers. I will eventually paint these black.
The extra flanges made it hard to have a neat installation. Material is still fairly "wavy" in appearance though.
I also put a metal rod inside the hollow area at the bottom to allow shaping the bottom edge some...and this will help hold the center part as the wind hits it.
As far as I can tell I gained maybe 1-2 mpg from this mod.
Carry on humans...we are extremely proud of you. ..................
Forty-six percent of Americans believe in the creationist view that God created humans in their present form at one time within the last 10,000 years. GALLUP POLL
