Old 05-09-2011, 12:10 PM   #12 (permalink)
Bill in Houston
Originally Posted by MechEngVT View Post
If you push the "AC" button it will toggle between AC ON and AC OFF. The AC OFF position will stop the compressor from running.
One thing to check - when you do this, make sure that the A/C is really going off. Elements and CR-Vs will tell you that the compressor is off, but it still cycles unless you do the hack. Our manual control Ody DOES shut off, however... Just something worth confirming.
