If you have access to a set of 13 inch Honda wheels/tires, I would try those out. 175/70/13s inflated to sidewall max psi would probably make a noticeable difference. Less rotational mass and a smaller contact patch along with maximum inflation pressure should give you a bump in mpg's.
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
