Fog collects in low lying areas because it is a result of a cold air drainage cooling air below its dewpoint, thus visualizing the cold air flow. Moisture condenses at higher altitudes when it is cooled below its dewpoint, often by anabatic winds moving up a slope, expanding as the pressure drops, and cooling as it expands.
