Lot of bright folks on these forums. *Doesn't surprise me.
Here are my project notes, so far...
DIESEL SPIDER PROJECT
goal: 100 MPG
=====Engines=====
Rabbit diesel
1.6L from Quantum
1.8L*
2.0L 140HP TDI from '04-'05 Passa
Subaru boxer diesel (import)
VW Lupo 1.3L *(import)
Merc Smart Diesel (?)
=====Transaxles=====
5spd Passat FWD
From whatever car the engine is from
=====Radiators=====
motorcycle*
Griffin alum.
Scirocco
550 FORUM NOTES
====TDIclub=====
MoT1, Pat Dolan, etc.
Yup, I'm running now with dual Honda rads in front of the front wheels, and it cools fine. I did a month-long, 8600 mile coast to coast trip in February this year.
RE: Kennedy Eng. -- Keep in mind that they offer the option of the 50 degree slant mounting as used in the Vanagon. You would need some Vanagon engine bits (oil pan, etc.) to make it work, but it would keep the engine low. That would work with either a swing or IRS Bug gearbox.
Another way to go full IRS would be with a VW water cooled gearbox. Transverse engine with a Rabbit/Golf/Jetta driveline (any series), or Quantum/Audi/Passat driveline for an in-line layout. More fab-work for sure, but the advantage to this would be 5 speed boxes and diesel-friendly ratios.
====Ecomodder=====
MoTheDiesel, basjoos
converted a 316 to 1.6L TDI from a Quantum. Used motorcycle radiators behind headlights.
====Samba=====
didget69, hstrecht65, BL3Manx
Rabbit diesel would fit Beetle transaxle with least trouble. *Need to fab exhaust & stash radiator somewhere.
