The Aspire had a Korean engine for one generation so it would be a gamble until you knew that it was the Mazda version, plus if I remember correctly it was always a cast iron block. The Korean engine has no aftermarket that I am aware of, and in this case you would want the Mazda variant which is just a smaller version of their 4 cylinder engine family at the time.
Originally Posted by Faster7
Thinking if the A15 gets really good mileage once it's injected, I can drive it while I work on the yaris setup. Then move it over into one of the "toys" and stick the yaris setup into the 240. I'm optimistic that the yaris motor in a base 240sx hatch with removed PS, no AC, etc might end up being even lower in weight than a Miata.... suggesting that it won't be that unpleasant to drive as far as acceleration goes.
It's true that the KA and even the SR are heavy engines so I don't doubt it could be light. The problem would be sourcing a cheap Yaris engine.
I'd like to get a 240sx hatch and put a Suzuki engine init because they're both light and small displacements. And then I'd built an engine for E85 but keep it a street car. I spent some time researching the G family hence why I brought it up. But right now I just need a car so I can get a job away from home. Someday I'll get around to it
