Old 05-12-2011, 01:30 AM   #9 (permalink)
mora
Golfwagen - '89 Volkswagen Golf mk2
90 day: 107.14 mpg (US)
You can input commands by typing them into a text field at lower right corner. First type the parameter you want to change, hit space and then type the value;
pc-time 20
This sets precharge time to 2 seconds. Should be easy. Parameters can be set temporary if you don't save the changes. Restarting the controller makes changes disappear then.
I haven't build 1k amp controller board yet so I have no idea how it behaves with RTD explorer. Maybe Paul can confirm if it works the same way like 500A version?
