Originally Posted by gikard
Has anyone considered running the inverter off of the ~270 V high voltage traction battery instead of from 12V? Some solar power inverters may accept the traction battery voltage. What's its voltage range anyway?
The one's I've read about used the NHW20, 04-09 Prius, and the 200V traction battery feeding a
modified 3kW, UPS inverter. I've exchanged e-mails with Richard and his is a serious project.
I've seen excellent progress with the solar panel inverters but the last time I checked, they were still fairly expensive, several thousand dollars for 3kW inverters. There is a lot of work going on in this area and if I wanted a turn-key system, I would search harder. But price remains a problem and the too frequent use just for emergency power.
Anther interesting development has been in the inexpensive, 5-6kW, gas generators. One of my co-workers bought a Coleman unit for ~$350 which is impressive since in addition to the gas engine there is the power electronics. Of course they have the advantage of being able to switch the high-frequency alternator to synthesize 60 Hz. But again, these are being sold as dedicated, emergency power.
My current investigation is looking at the 33 kW, MG2 inverter that is water-cooled and already integrated in the car. When parked, MG1 can continue to provide power up to 18 kW and just needs a fuel supply, say natural gas. These are the NHW11, 2001-03 model Prius and can be bought for ~$5k. If done right, the Prius can plug-in to the house to generate power and later still deliver +50 MPG. Add hot water heating and possibly space heating, we're talking a mobile, co-generator.
Bob Wilson
