Old 05-12-2011, 05:25 AM   #41 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by hu_man View Post
The high tire pressure will increase the stiffness of the ride increase the chance of the car to push a little more and it will most of all increase the wear on the center of the tire...
Tyre pressure indicated by the car manufacturer are often too low.
If higher inflation spreads out the wear better, higher inflation can reduce tyre wear.
Obviously you need to check and monitor it over time.
At 3.5 bar / 51psi I'm finally seeing even tyre wear across the thread, in addition to reduced fuel consumption.
YMMV.
Aside from reduced rolling resistance, higher inflating leads to reduced tyre deformation, resulting in less heat in the tyres, and less heat means less wear.
Watch your tires closely the cost saved at the pump could be less then a new set of tires or a fender.....
That's something that every driver should do, regardless of the pressure in their tyres.
Hypermilers are looking at their tyres far more often than the regular John & Jane Doe.
We'll be fine, thank you
