Old 05-12-2011, 05:33 AM   #42 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Enginator View Post
Running tire pressure at 45 psi or higher increases danger of loss of control, bouncing and the suspension is NOT tuned for it.
I've only experienced bouncing when going beyond the max. rated tyre pressure - 51 psi (as rated by the tyre manufacturer)
It can affect stopping distance.
I don't have the slightest indication that it actually has increased my stopping distances.
Low rolling resistance tyres have reduced my stopping distances over the sportly rubber I used to mount before.
The later pressure increase doesn't appear to have had a further deteriorating effect.
Plus the tires will not last as long.
Everything is pointing to my tyres lasting longer @ 51 psi than @ any lower pressure before.
