Old 05-12-2011, 07:59 AM   #1 (permalink)
jackbauer
jackbauer's Avatar
Home charge point
I'm working out a design for a simple home charge point to install at my home. In Ireland , homes are fed with 240v 63amps single phase. My onboard charger is 5kw so i need a 32 amp socket. I'm also planning to install 16amp and 13amp sockets protected by an rcd and housed in a metal ip rated enclosure. Can anyone think of what else I could or should include to make it as universal as possible?
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
