Old 05-12-2011, 02:33 PM   #7 (permalink)
theycallmeebryan
2003 Ninja EX250 - '03 Kawasaki Ninja EX250
90 day: 78.57 mpg (US)
Saturn - '99 Saturn SL1 Base
90 day: 47.27 mpg (US)
I've got a 99' SL. I've been right around the 45-48mpg range since i've bought the car. I've got a vacuum gauge installed and do a lot of EOC, not so much pulse and glide though.
Make sure you keep this guy's ebay page saved.
Saturn Shifter Bushing Cable Replacement End Loop | eBay
These saturns are NOTORIOUS for faulty shifter cables. Specifically, connection between the metal cable and the plastic eyelet is a horrible design. The connection is so weak that it breaks very easily. Don't waste your money on buying a new shift cable, because it will do the same thing 2 weeks after you install it (the dorman cables are worse than the OEM ones).
Doing my part to reduce dependence on OIL
Doing my part to reduce congestion
And enjoying it!
If you have to use your brakes, you are driving too fast!
My 101.5 MPG 2003 Kawasaki Ninja 250
Crude Oil Price Today
