Old 05-12-2011, 02:57 PM   #19 (permalink)
shovel
wouldn't it be smartest to make a "sealed" (or at least closed-off, aerodynamically) engine compartment and a separate, aero-clean cooling tunnel with a radiator in the middle of it? It could dump to just under/behind the front tires perhaps... or wherever there's naturally a low pressure area.
I recall the 93 VW Fox I used to drive had a tiny radiator off to one side, the right 2/3 of the grille was blocked by a cardboard panel and air got diverted into the little square radiator... it wasn't super slick but I don't see why the same idea couldn't apply to something like the Focus, and not even need mechanical shutters (that will inevitably fail)
Work From Home mod has saved more fuel than everything else put together.
